Table Saw Upgrade
randgbruce
2 Nov 2011
prestonpans
Can anyone reccomend a fence upgrade for a startrite(12"0) Table Saw.
On the one i have there is no adjustment screws to make it parralell to the blade.
Many thanks
boo :? :?
I have now managed to sort table fence, I have found that the fence on my startrite table saw
is from a wadkin table saw & now no how to adjust.
Presumably the fence is attached to some sort of rail at the fron of the machine, that being the case, can you not shim one of the bolts holding it to the machine so that the fence is parallel to the blade?
Thanks for your reply, but have managed to sort problem, the fence runs on splines so all
you do is pull handle outwards & set fence then re-engage handle into splines. :D :D :D
