Ok, this design is a little bit Heath Robinson I guess, but needs must. I neither have the funds or the space for a large TS.
I want to expand the size of my table space, and have designed in extensions that are removable and adjustable. The legs will fold into the base, to make it easier to store. The TS itself will be bolted to a bit of ply, which is then bolted to the table. I will also have height adjusters on the TS, so the top surface can be aligned with the extensions.
The blue feed in/out extensions can be clipped into three different positions, are hinged, and are propped up with adjustable arms. I've made the side of the stand open on the right, so that I can slide the saw into/out of position. Also, there's nothing to interfere with the fence being used on the right hand side, which is useful. The dark grey items are bits of steel hardware. I think I can use hardware for reinforcing joists with a little luck. At some point I will convert the end of the table into a Router table.
So far the plan is to build it all from C+ Grade Elliottis Plywood, 18mm, laminated into extra wide parts where necessary. I haven't worked out how much materials I need, but hopefully I can build this out of an 8x4.
I would love a TS which didn't require any of this setup, but sadly it's not to be. On the plus side, I can use this setup to work outside in the good weather, which would be nice!
All comments and crits welcome. I haven't finalised the design, and would be happy to consider any ideas for improvements.
