Table Saw Mod
Seiken
28 Feb 2017
Camberley
After using my (cheap) table saw for years with no riving knife therefore no crown guard and the neversquare fence now I've retired I decided to spend the time and rectify things. Cut down the riving knife and re-attached it, drilled a 25mm hole in the guard and fitted a bit of pipe for dust extraction hung the whole thing off a steel cantilever assembly bolted to the end of the table. By removing one fixing bolt the whole assembly swings below the back of the table so I can use my homemade tenoning jig.
Made the fence using pocket screws, the tee guide has some adjustment so to square the fence to the blade is an easy task.
