Table Saw Blade Advice please for cutting plastic
steve007
30 Jun 2014
Nottinghamshire
looking for a 200mm with or around that size for my axmister TS200 30mm bore
to cut 4mm polycarbinate sheet i know its got to be a Triple ground blade but i cant find nothing really need help if anyone can point me in the right direction
many thanks steve
ComfortablyNumb":3eo1oqh1 said:
http://www.ffx.co.uk/tools/product/Freud-Lp40M-016-8025331202628-200-X-2.4-X-30-X-40T-Cross-Cutting-Saw-Blade it says x-cutting blade but that's because it is triple cut grind
the knife on the saw is only 2mm the blades i get from axminster are 2.2mm will the 2.4mm Freud be ok ?
should be, according to this thread circular-saw-blade-t7232-15.html
I've used my 250mm 48 tooth version of this blade to cut 6mm polycarb with no problems at all. No burning or chipping at all. Perfect cut in fact.
