steamboat
Has anyone got some advice for me?
I am making a dining room table out of pippy oak. The legs are about 3’x3’ made up of four pieces glued together. Two of the legs have started coming apart along the glue lines (less than 1mm), I suppose the wood wasn’t as dry as it should have been.
So my question is how do I fix it? My initial thought is to cut shallow 45 degree edges along the sides \_____/ that are coming apart and then router the remaining out of the middle, I would then cut a corresponding piece of wood to fit into the gap. This way it would cover up the glue lines and give a nice finished side, my only concern is that the glued in section would stop the natural wood movement and cause more problems.
Thanks in advance
Thanks in advance
