Grain88748
I've never had cause to use a stud detector so don't know much about them. What do folks think of them? Do the cheaper ones work reasonably well and will they find joists beneath flooring chipboard? Thanks.
You could ask Joan Collins what she uses...Grain88748":1igewsvg said:I've never had cause to use a stud detector so don't know much about them.
Imagination is more important than knowledge...
Albert Einstein (hammer)
bosshogg":lo9uzck5 said:You don't need a stud finder to find studs or joists, just a hammer and a good ear.
Everything struck by a hammer has a reverberating tone, according to density/thickness and if you tap along a wall or floor you can detect the difference where the covering boards go over a stud/joist. Mark your estimation on the floor board, and hammer a nail in the centre to confirm a joist. Coat the nail shank in soap to allow easy removal, once you've established one, measuring the centres of studs/joists is simple. On modern floors they will be metric, on older they will be imperial (use 1970 as an approx of the change over date) Metric will be set at either 400 or 600mm, imperial 18" or 24" (both are an approximation of the other) :idea: Remember to establish approx distance with the hammer before measuring, where it's almost right by sound it will be right by the rule :idea:
Hope this helps...bosshogg![]()
Register today and take advantage of membership benefits.
