Startrite SD300 p/t judder
RussHogg
New member
10 Feb 2016
Reading
Hi all
I have a Startrite Sd300 planer/thicknesser, 3-4 years old, and finding that when thicknessing there's sometimes this rythmic judder/clanking as the stock goes through...it otherwise performs ok. I've heard it described as a bit of a 'design fault', and wondered if any other owners have experienced this?
Any thoughts much appreciated
Russ
Ah, thank you, it sounds like that - the manual talks about how to re-tension the belts, but not the chain, might have to give startrite/record a call
Hi Russ,
Did you manage to solve the judder problem? I have just picked up the same machine and am experiencing the same issue.
Cheers, Jamie
