Stainless Steel inlay
stev
5 Aug 2009
Cirencester
Hello all,
As part of my latest project I need to inlay some small stainless steel panels (100 x 80mm 2mm thick) into the centre of my veneered doors. My question is, what adhesive is best for this job?
After routing out the mortice for these I will be left with a very porous MDF surface and a hard stainless steel surface so what would be effective for joining these two materials?
Your experiences and opinions would be helpful.
Thank you
Steve
Boatfixer
15 Sep 2008
North East
I use Sikaflex 291 to attach stainless tops to mdf subframes for vets operating tables. Never been able to get one off again in one piece..... DAMHIKT!!!
Graham
yetloh
1 Dec 2008
Sussex
I would go with Graham's suggestion and definitely avoid epoxy of any sort. Some years ago I needed to veneer ss with maple for a structural component. Even after sand etching and degreasing epoxy would not form a strong bond. I did eventually find a two part adhesive whcih was highly effective but came with all sorts of warnings about liver and kidney damage from fumes and it certainly did smell evil. Can't remember what it was called now but if I had to do it again, I would go with the Sikaflex.
Jim
Harbo
13 Nov 2006
Hampshire
There's a recent article in Pop Wood where the founder of Bridge City Tools is recommending gluing brass inserts to wood using contact adhesive?
From the pictures it looks like a Titebond one?
Rod
Hitch
28 Jan 2006
Somerset
That Sikaflex is some sticky stuff, just dont put too much on!
mtr1
10 Oct 2009
North Norfolk
Just to throw something traditional in the mix.......rub garlic on both surfaces, then use scotch glue. I have done some restoration with pewter inlay using this method, it had been done like this previously and had lasted 150yrs. Also it was easy to restore, without harm to the rather spendy antique.
bosshogg
9 Mar 2011
N E Scotland
If you are suggesting that the SS plates will be inlayed within the surrounding veneers, then double sided tape will do the job. Using VHB (very high bond), which is made for industrial performance, is clean, quick and instant. The general purpose ranges, tend to bond to dissimilar materials, so go for one of these, or you may have a roll lying about and have not thought of this...bosshogg
stev
5 Aug 2009
Cirencester
Thank you all for the help. I'm going with Bosshogg's suggestion of VHB tape as it sounds like it will be more than strong enough to hold a few grams of steel but more importantly it does away with the squeeze out problems of liquid adhesive. I'll let you know how I get on.
dickm
25 Oct 2004
North of Aberdeen
Is that a wind up?? :D? As a Scotch glue enthusiast, that's an idea I'd never come across :)
Boatfixer
15 Sep 2008
North East
I had not thought of double sided tape - I am assembling a table this morning and will give it a go instead of the Sikaflex. It sounds quicker and cleaner......
Graham
AndyT
24 Jul 2007
Bristol
It's not a wind-up. I don't have it myself, but any Scotch glue enthusiast should have Stephen Shepherd's book on it, or at least read his excellent blog. See this page for references to hide glue with garlic for sticking metals!
twothumbs
13 May 2011
Edinburgh
Ernest Joyce mentions garlic rubbed on prior to sticking together even with araldite, or hide glue plus some turpentine. or the addition of plaster of paris. For me I have done none of these but interested to hear how it goes. Good luck.
jimi43
12 Mar 2009
Kent - the Garden of England
And it keeps out vampires!
:mrgreen:
Jim
dickm
25 Oct 2004
North of Aberdeen
Thanks for the ref to the Shepherd book - off to the library anyway tomorrow, so will see whether Aberdeenshire can find it anywhere.
