TobyB
I have a Hofmann & Hammer workbench I acquired a few years ago ... very solid and stable, compact for my small workshop, but it has 2 end and 2 side vices which works well for me as it lies in the centre of the room ...
Problem is, the main side vice I use has developed a considerable degree of skew in the last couple of years. If I close it up, when the right-hand corner of the jaws just touch, there's a 4mm gap at the left-hand corner ... cramp it up REALLY tight and it holds fairly evenly ... but ... not great ...
This vice is a "conventional" central metal screw with two parallel guide rods either side compressing two solid wooden jaws ... don't know the make, seems to be German, perhaps "GS" ...
Is the best way of correcting the skew to mark the angular difference on the outer jaw, then take the vice apart, plane down the outer jaw (i.e. take a triangle off, 4 mm on the right down to zero on the left) to balance it? Or should I be trying to work out right-angles to the metal hardware and align inner and outer faces to these perpendiculars? Or what?
Is this likely to be a one-off "fix", or a "regular maintenance" issue if wood moves and moves ...
