They can be repaired with hard wax but it really isn't worth the bother it is just as easy to strip the kit down and remake them the splits can be caused by several things, sanding with the lathe running to fast so the wood overheats and splits which can happen well after the pen was made or glue residue inside the tube making the fit of the pen components being to tight good luck with your next batch
