Spline jig MkII
woodbloke
13 Apr 2006
Salisbury, UK
The previous jig using the t/s was OK for pic frames but the saw tooth profile was left on the bottom of the slot, not too good. Couldn't do boxes with it either. I've got someone coming down to Wilton in a couple of weeks who wants to do a rather special box, so I had to get the thinking bonnet on and I quickly knocked up this morning, in a shop that read -3decC on the thermometer, this:
which'll do pic frames and a box of up to about 125mm in depth :wink: I tried it out on a bit of pine with a 6mm cutter in the router and it works fine, I've also got a 4mm cutter for doing smaller splines - Rob
:lol: Wonder who that is, Rob????
Karl
Looks interesting, can't wait to see who your next visitor is! Better warm up that workshop if your teaching in this weather!
Worry not...it'll be warm :) - Rob
if I am understanding it correctly will that jig do a spline with its bottom always at the same point ? therefore being a shallower or deeper spline depending on the wood thickness (as the top doesn't move up and down ?
apologies for daft question, just want to understand how the jig works
ta
ta
Pual - the frame or box is set between the two pieces of oak and clamped. The corner is then level with the top of the mdf and it's a simple series of cuts then with a router and fence down the required depth - Rob
Excellent jig, Rob - might pinch that idea 8)
If it's any consolation, I reckon it's been less than -3 degrees in my workshop :(
Cheers :wink:
Paul
I've been meaning to make one for a while, but I was planning on doing it the other way up and running it against the router table fence.
Am I right in thinking that your Mk.1 jig was the other way up and if so, what is the reason for changing? Just wondered...
Cheers, Ed
ta
doh !
thanks for that :D
Cheers, Ed
Ed - on the MKI jig, the saw blade was used to make the slot and this worked very well. The disadvantage using the saw blade (in addition to removing the guard and riving knife) was that the bottom of the slot was the same shape as the profile of the saw blade teeth, a shallow inverted 'V' so that there was never a chance :x of totaly filing it with the reinforcing timber at the bottom - Rob
Rob
Yes I realise that Mk 1 used the saw and Mk 2 uses a router, but what I was getting at what was why is it the other way up for the router?
Cheers, Ed
EdSutton":27x0vhc2 said:
Rob
Cheers, Ed
Ah...I see. I've got smaller bits for the hand router as opposed to the table, smaller bits of course being more suitable for boxes and pic frames - Rob
woodbloke":1i4il64d said:
EdSutton":1i4il64d said:
Rob
Cheers, Ed
Ah, now I see. :D Just checking you weren't onto something I'd missed when I come to make mine.
Cheers, Ed
