Spear and Jackson hand saw
REN
28 Apr 2021
Keighley
Hi all,
I’ve finally embarked on having a go at sharpening my hand saws with some measure of success (thanks to U tube) on my tennon saws. Now need to move onto a large Spear and Jackson 650mm handsaw model B99, (it says on the sleeve ).i
I’ve made a jig to fit onto my workhorse to hold the saw tight. My problem is the handle is slightly loose. On my tennon saws the brass studs fixing the handles to the blade just unscrews easy. Please does anyone know it it’s the same with the Spear and Jackson saw as I don’t want to force anything?
    143.1 KB
    374.1 KB
I reshaped a couple of those handles and found those are press rivets so you have to destroy then to get the handle off. Being rivets you could simply bang them up a bit tighter with a hammer. Support the other end on something solid.
Regards
Thanks John. I’ll give a gentle knock a try as you suggest.Obviously a cheaper production technique.
I’m quite keen on sharpening this handsaw as efforts on sharpening smaller saw have proved it not that hard to do.
I use the bow saw quite often as I don’t posses a jig saw. The dove saw was a bit of a challenge with 19 points to the inch. I’ve returned to tennon saws rather the the Japanese type which good but I’m unable to resharpen.
    2 MB
Hi Ren,
Will be no problem if you can sharpen small teeth. 10 tpi and larger is a walk in the park compared to small teeth.
Here are the ones I saved. Guy was going to bin them as they were blunt. Both 7 tpi so made one into a rip and needed to be able to tell them apart.
Regards
You don't show the reverse side of the saw handle. If there is a screw slot, it is probably a nut - so you can just screw it up tighter [after adding a small squirt of WD40/Plus=Gas/BDX Bulldog and waiting].
If there's no slot, it'll be a two-piece rivet. In which case : either a hammer [but you risk splitting the wood] or put each rivet in turn into a corner of a mechanic's vise, and giving it a squeeze.
Hi Ren,
Regards
Hi Ren,
Regards
Hi John,
Nice job,they look good and I imagine they cut well too. How nice it is to use a saw that cut easy, no force required letting the sharp teeth do the job with the minimum of effort.
Roy
