David C":3rny807d said:If one takes the trouble to master the various techniques for raising effective pitch, one can plane anything. Albeit with fine shavings.
The scraper plane then becomes redundant for everything except complex veneered surfaces.
David C":2vp5smo1 said:I wrote about surface finish in my third book. If your chosen finish needs sanding between coats, on a table top say, I think that a little sanding will be essential to achieve flatness, regardless of which tool is chosen to prepare the surface.
pam niedermayer":pphyu5ye said:Big difference between sanding the wood and sanding the finish.
Paul Kierstead":2yxykbom said:pam niedermayer":2yxykbom said:Big difference between sanding the wood and sanding the finish.
The article is -- in part -- concerned with the need to sand the wood if you are going to sand the finish as any scalloping left on the wood can play havoc since the peaks will have the finish sanded through. It is worth reading.
Paul Kierstead":33gvjjs3 said:It is worth reading.
dchenard":xm9c8cpo said:
David C":klpsitg0 said:DC-C,
I like to use very thin wiped on shellac, a method developed from Krenov.
If any scalloping or burnishing lines are left on a plain surface like Swiss pear we seem to see streaks or unevenness in the finish film, which is very very thin.
This only shows at very low incident viewing angles using a good light source like a bright grey sky.
I deduced that the film thickness varys if the surface is not completely "without scallop" and uniform in appearance before the first coat of shellac. Hence my practice of light sanding to flatten and make the appearance uniform.
Sanding through these ultra thin films is a problem as they are nowhere near the thickness of varnish.
I don't doubt that a leg surface say, can be completely flat and perfect, if the timber is mild and cut with a straight blade, perfectly sharp plane.
Scraped surfaces of difficult timber are not as bright or perfect, and sanded surfaces are in fact a mass of uniform scratches.
Back bevel surfaces on difficult stuff also benefit from a little fine sanding, but they do exhibit zero tearout.
These are all very small differences, but really good finishing seems to be a difficult and precise art.
It would be so nice to leave wood unfinished, straight from the plane, but these surfaces can become disapointingly dirty some years later?
best wishes,
David
Paul Kierstead":11ifcf8s said:David C":11ifcf8s said:If one takes the trouble to master the various techniques for raising effective pitch, one can plane anything. Albeit with fine shavings.
This is not a rhetorical or critical question: Why do we want to make the scraper plane redundant? Not that I am against high-angle planes; I have a plane set at 52.5 degrees coming. But I do wonder why sometimes we work so hard to plane something when it could easily be scraped (or, I suppose, sanded, but that is a different kettle of fish). Is the planed surface that superior? I take it you do not subscribe to the results published a while back that found no differences in surface quality between the various methods in a finished surface.
I'd be interested in hearing your thoughts on the merits of planing, scraping and sanding.
bugbear":2w43qrfh said:Steve Knight's research indicated that planing at the lowest EP that avoids tearout (which may well be quite high by "normal" standards) does indeed give a better finish than scraping.
I would further maintain that sharpening a plane blade is easier than sharpening a scraper blade, and that edge retention is better in the plane.
