Small adjustable Reamer
AndyNC
20 Jun 2011
Hi,
Do adjustable reamers less than 1/4" exist?
I can find one that go from 1/4" up to 9/32" but not smaller.
I'm trying to make bushes for an odd size mandrel (0.246").
A Letter D size drill is to small and a 1/4" reamer to big. A 6.3mm drill may work but I don't have one and I would prefer a reamer.
Many thanks
Andy
Have you considered making a D bit out of a bit of silver steel? You could turn this up, mill or file the end and harden and temper. Useful to get an accurate reamed hole. Bit small to bore with a boring bar I would have thought.
Thanks for the suggestions.
Porker: I have some 1/4 silver steel so annealing, turning to get a nice fit, grinding to shape and hardening sounds like a nice little job.
Inspector: I don't think I have a boring bar small enough at the moment. Although I've been given a tray of tool steel so grinding one wouldn't be an issue.
Spindle: I may give these a go if the D-reamer doesn't work. The letter D drill was too small D=6.2484mm so 6.25 sounds like the right starting place. I normally ignore the sent from china items on ebay because I have heard some poor reports on delivery.
Many thanks
Andy
PS: Off on hols at weekend so no action for two weeks.
Hi
If you're going down the drilling route 0.246" is a letter D drill bit - drill and lap will be easier than trying to take a one thou cut off of silver steel.
Regards Mick
Hi,
Tried the D reamer method but I couldn't anneal it well. I only have a propane torch and could only get it just red. I need some fire bricks or a little oven made from thermalite or celcon blocks.
Tried drilling and boring and had some success. I got the ID good fit but I fluffed the outer dimension. In the tray of tool steel I found a suitable cutter ground down to about 3/16 with a little nose on it. I think my father has been down this route before.
I started again and this time the D gauge drill drilled it out to a good fit. I'm not sure why but I did note that there was more swarf off one flute than the other leading me to believe that the drill was not central although I used a centre drill to start with.
At least this has got me to the second stage.
I might give the 6.25mm adjustable reamer a try.
Andy
