Skull
Dominik Pierog
31 Jul 2010
Poland
Ok I cheated this is cardboard and laser cut.
Project gallery > http://decodrew.deviantart.com/gallery/52787462/Skull
DXF project two types of cross section horizontal and vertical > http://www.cnc.info.pl/download.htm?id=26285&special=68
Project generate on 123D make
https://www.youtube.com/watch?v=jo5TxtKLmjM
But you can use scroll saw, scalpel or different technique.
Material thickness 3mm that could by : plywood, cardboard, pleksiglas, foam, rubber etc.
It's easy and cheap project. Time consuming 1-2 hours for 5 days.
I use wood acrylic filler, water dissolve. After drying I think is waterproof.
60 layers/parts glued in 1 hour.
Add filler
After first sanding
Repeated 6-8 times
I make final coat using wood glue, little filler add, black dye, all dissolved in water.
Paint test
Sanded.
After painting, little sanding, painting and painting again....
Do you have a laser cutter, or did you get it done by a company? I believe they're pretty reasonably prices nowadays.
I have laser cutter for live (earn money).
Scroll saw is hobby.
Also i can design and make really precision parts from plywood.
Haha my workstation in home :)
Cool! I've thought about getting a cheap one. Is it a good business?nwhat kind of things do you sell the most of?
A huge market, believe it or not. From angsty teens to metal fans and gamers, skulls in any form sell. I sold a load of skull and crossbone Christmas decs this year.
I think the degree of repetition involved means that (almost?) no-one
would actually make it using manual techniques.
BugBear
BugBear
I think Steve Good made a pattern for a head, then decided to cut it to prove it could be done, though I don't recall seeing the finished item.
