garywayne
Hi.
I have a problem with using "Follow Me" the way Dave R mentions in "SU Project for beginners".
Dave R Wrote:-
"I also put in the chamfer on the top outer edges. I started the chamfer as I did on the rail but since it continues around the corner, I used Follow Me to make it. there are a couple of ways to handle the Follow Me operation. I like to select the path before selecting the tool.
Then select the Follow Me tool (I have F set as a shortcut for that) and click on the triangular face. Presto! Chamfers".
I have only been able to select one line at a time. How do you select two lines that are at right angles to each other?
I hope this makes sense. If not, don't hesitate to ask.
Dave R Wrote:-
