Mark A
I've started to fix my shed to make it slightly more comfortable this winter. I took the roof off last weekend, cleaned it up and put it back on with big tek screws and StixAll, so the leaks are now sorted.
Stage 2 is the floor. Currently the shed is fixed to some 3x2s,which are resting on a concrete base with a tarpaulin between. I'm planning to replace the old 3x2s with a 6x2s, then use 4x2s for the floor joists.
Here's a sketch up drawing of what I mean
First question: Do I need to incorporate some sort of ventilation? There will be a 2" gap between the DPM and the joists, so do I need to cut notches/ drill holes in the 6x2's so damp air can escape or will it be ok?
Second question: What type of insulation will be best (and cheapest) to go between the joists? I'm guessing it's polystyrene but would fibre glass loft insulation work too if I held it in place securely?
Thanks,
Mark
Thanks,
Mark
