Hi. Its not exactly a workshop that am building but a small Greenhouse/shed. (This seemed the most appropriate sub-forum to post in). It won't be the most glamorous construction. I just want the space to store some pots, grow tomatoes and propagate things.
The general plan is:
At this early stage in the planning I have come up with a few issues:
OK I think that's is. Even though I want to keep costs to a minimum I know that this may not sit well alongside the reality of building something useful and enduring.
Anyway, thanks for your patience ( if you get this far through my post.
Any input would be greatly appreciated.
Jon
- Footprint - 3x2m approx.
Plinth - Concrete foundation > single course of 215 x440x100mm block > DPC .
Framing - 3x2 (400mm OC)
Windows and a Door - x3 salvaged
Roof - Single Pitch. 1/3 slope (4/12 Pitch). x5 - 2.4 x 0.6 Mtr Corrugated PVC sheets.
Shiplap - for the wall areas without windows
- 1. Rafters. For the Single Pitch roof I was planning on using 4x2 at 400mm OC but the span from (outside) of wall to wall is 1960mm. I am worried that this might be too great a span for 4x2. Would I be better increasing to 6x2 or using a Gable roof?
2. Headers. The largest window is 2032mm wide. I was planning on using a laminated 4x2 + 4x1 above this for the header. I am thinking that this is maybe not beefy enough? the stud work is 3x2 so I cannot go wider but a could go deeper. (the other two windows are 1360mm wide).
3. Bracing.. Three of the walls have mostly window so there will be little space for diagonal bracing. On one wall there will only be space for noggins either side of the large window. Any ideas on how to stiffen up such a wall?
4. Plinth. I was thinking of attaching the P/T 4x2 Sill Plate to the Block plinth with hammer fixings. https://www.screwfix.com/p/fischer-nylon-hammerfix-8-x-100mm-50-pack/33940?_requestid=154229 Are these going to be strong enough? They will also penetrate the DPC. Will a blob of silicone down the hole be OK?
Jon
