beaver
Hi Guys
Bear with me as this may need some explaining, i've got an aw106pt2 p/t,but dont have a great deal of experience setting the knives.ive watched a lot of videos on this subject but something bothers me, it comes with the normal setting tool, and all being equal this sets the blades parallel to the cutting block, but this in turn might not be parallel to the table, ok so i can then adjust the table to the blade/block. in a lot of the videos they use a dial gauge to set the blades parallel to the table, now heres my problem will that then mean when i thickness this may have a run out as the knives could be parallel to the planer table but not the thicknesser bed underneath. hope this makes sense, basically can someone explain the best way to set this up.
