Securing workpiece on MFT
Roboboyo
25 Apr 2022
London
Ok guys.
So I’m setting up a cut on my MFT. I have the rail locked and stable but my workpiece has no support
Is there any clamps I can use to secure the workpiece so that it’s not moving when plunge cutting ?
Many thanks
Ok guys.
Many thanks
Of course, if you want Festool
if you want others then hear are a few other choices, there are quite a few others.
I've got the red handled clamps above and they're really decent. I believe I bought them from Ali express for cheap
One of my original issues with the mft benchs and why I delayed going down that route. I solved it by using the microjig slots inbetween the 20mm holes so now I use dogs for alignment and microjig clamps tp hold things down and it really makes the mft more usable.
and you could purchase here Micro Jig MATCHFIT Dovetail Hardware Variety Pack
I just use the normal festool screw ones, second down on the left in the pictures from @sometimewoodworker `s post.
Cheaper copies are available.
However, normally the workpiece is pushed up against some dogs for squareness anyway and this is enough support. Mostly I don`t need to clamp it unless it is a particularly small or an awkward shape.
Ollie
Worrying unnecessarily perhaps? With a reasonable sized workpiece, clean rail and the weight of the tracksaw, don't push it hard and nothing will move?
Try it and see?
