Sealing/finish for Birch Ply end grain
Mark18PLL
15 Mar 2020
Lancashire
Hello again ,
I am making a desk out of birch ply, i have sanded the edges to a smooth finish but want to seal with some sort of varnish, what would you suggest?
Mark
Droogs
Is that chisel shar ... Ow
14 Mar 2013
Edinburgh
depends what your final finish is going to be. but in general the best things is shellac as it is easy to use and will not react anyother finish you finally put on.
hth
Mark18PLL
15 Mar 2020
Lancashire
Great, thanks. Can you recommend a good brand to use or are they all pretty much the same?
Mark
Droogs
14 Mar 2013
Edinburgh
Zinsser or Liberon wood sealer are shellac based first coats for any wood type
TheUnicorn
21 Feb 2020
South West
slightly off topic but I used zinzer B-I-N (shellac based I believe) as a base coat on mdf recently, edges and face, it seemed to do a great job of sealing the mdf, followed up with a coat of emulsion.
