Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
I ordered a large-ish radiator and collected and hung it yesterday. It's "Kudox", 1800x600 single panel, fins to the back and a clip on cover.
I was expecting, and got, three brackets. "Simples" thought I, so measured the centre line of the reveal, and dropped a vertical. I checked the final position of the 9" skirting, and that everything cleared it (including the thermostat - been caught before!).
They'd put in the wrong instructions -- for a 2-bracket rad -- all the distances were irrelevant.
It also said "use a 9mm masonry bit" for the wall plugs (a thing I've never seen outside of the "stupidly expensive" rack in my local specialist tool shop). 8mm was definitely too small, and even if I had 9mm, that looked too small as well. The plugs taper, so I compromised on drilling to depth at 8mm and enlarging half the hole to 10mm. That was fine.
Before drilling though I re-checked measurements on the rad. Boy, am I glad I did. From centre to end: 770mm. Fine. Marked off verticals at 770 from the C/L.
At this point something (someone: I do believe in the Almighty) made me check the other end of the rad: 800mm, NOT 770mm. The middle bracket is offset by 15mm.
I heaved a sigh, made more pencil marks (wall beginning to look like a mini version of Nasca, Peru), and drilled and fitted the brackets.
Three brackets, six coachbolts, six washers (supplied by me!), six holes, and a centred, level radiator. Result!
But it so nearly wasn't. How many houses have walls resembling Emmental cheese I wonder?
And I still have to paint the back of the thing, where they couldn't be bothered to spray it properly. It's almost bare metal inside the fins, and does have bare metal where the clip-on cover has scraped one of the spigots.
The alternative is packing it up, arguing about it, sending it back, getting another brand and making more holes in the wall. The single-with-fins ones are probably all like that, sir (all the bigger ones I've fitted recently have been doubles, so the brackets are on the rad, not the fins). But hey, a warning would've been nice...
Screwfix: Aaargh!
E.
Screwfix: Aaargh!
E.
