shim20
dose anyone know of a book with detailed information on how to make these, its something i would like to know how to make.
cheers
ben
cheers
ben
Cheshirechappie":2thdyer7 said:Try 'Modern Practical Joinery' by George Ellis.
AndyT":2i8atec7 said:A lot depends on whether you want to make them by hand or with machinery. Plenty of books show a diagram or two of the general construction, but leave out lots about the sequence of operations and how to make your case and sashes fit the opening in the wall.
There is a rather good detailed book that The Woodworker reprinted in the 70s, written about 1920 I think, that describes hand techniques. Not easy to find; there was this copy on eBay recently.
Probably a lot more useful - as it is available in full, for free, is Cassell's Carpentry and Joinery, from 1907, edited by Paul Hasluck. Start here to read on-line or here to download as a pdf.
It assumes handwork throughout, and is reassuringly detailed, showing how to make and use a rod for the dimensions, and also some special templates for marking out the joints.
There's also a useful (but inevitably brief) video by Roy Underhill that shows how to plane up sash sections here.
I'd be interested in a wip if you do decide to do it the trad way!
AndyT":an1cwppr said:It would be fascinating if you could make at least one by hand. It's something I'd like to try but have no need to do.
Reading through the descriptions, and thinking about the millions of hand made windows that were built in the C18th and 19th, one huge difference between then and now is in the cost of setting oneself up to make them.
With the hand tool approach, you'd need:
a bench;
rip, crosscut and back saws, also a padsaw;
planes - jack, try, smoother, plough, fillister, rebate and moulding planes for each pattern/size of moulding
brace and bits
chisels, scribing gouge
rule and square.
So, apart from the bench, you could fit all the tools into a joiner's tool basket.
Nowadays you'd be looking at:
Sawbench
Planer
Thicknesser
Spindle moulder
Morticer
Dust extraction system
Needing lots of space and costing tens of thousands. The barrier to entry is much higher.
Benchwayze":399qikgc said:Is this of any use to you shim?
http://www.gifford-park-assoc.org/Makin ... HBLeke.pdf
Just save it to your hard drive.
HTH![]()
shim20":qw0znu6d said:dose anyone know of a book with detailed information on how to make these, its something i would like to know how to make.
cheers
ben
thanksphil.p":1w8lxc7p said:shim20-all done!
shim20":ayjfn1ey said:just came today, was just the book i was looking for thanksdose anyone know what sort of moulding plane i would need to do the mouldings by hand? something like a Fillester Moulding Plane? or a stanley 55?
Register today and take advantage of membership benefits.
