Exactly what Eugene said. The last half of the cutting must contain some butt clenching moments! Beautiful finished job though.
Do you have to follow round and sand all the cuts when it is done? That must be a tedious job too.
Oh and welcome to the forums!
If you use a fine enough blade, that eliminates most sanding on the internal cuts. A careful circular rub on some 240grit gets the patter residue and the fuzz off the bottom face. There is no finish on this one, it was pressed into immediate service as soon as the glue dried! I'm lucky to have a 14inch band saw, so I can resaw endless quantities of solid wood up to 12 inches wide for projects like this.
Thanks for your comments Keith.
I've been toying with the idea of buying a scroll saw for a while now and I think the time when I part with some cash is getting ever closer.
