billybuntus
Anyone bought one? I have and I'm frustrated to say the least.
Just come back from the trade show at harrogate and not having bought anything I thought I'd crack on and assemble my MR MDF wardrobe carcase.
After very carefully making six pocket holes in each corner I set about screwing it together. My first attempt saw that the assembly pulled 1/16th out as I was warned. So I clamped up the corner and set about driving in the (self tapping?) pocket screws with my dewalt driver at which point it didn't pull up correctly then sheared off.
I then drilled the screw head out and separated the corner. I decided that I should try doing it up by hand which had the exact same affect of not pulling up and shearing off I must saw that I've never sheared a screw head off by hand. By not pulling up I mean it gets to within 1/2 mm gap and clearly hasn't tightened up the joint.
I then decided to repeat the procedure with two new pocket holes but pre-drilling the holes with a 2.5 mm drill as the supplied drill does not go full depth.
This also had the exact same shearing affect.
I'm a little annoyed but I want to find a solution as I like the concept. I'm using 18mm decent quality MR MDF.
Could it be that the screws are poor quality and maybe of the fine variety rather than the course I need for MDF?
Also. In between all this the square driver bits supplied both round off after two uses. Not good. The actual jig seems pretty decent.
Yours hopefully
Billy
Yours hopefully
Billy
