router tables and height adjustment
mukka
17 Nov 2005
checking out above wanna know if i missed anything
woodpeckers unilift
routalift
routerraizer
rout r lift
for router that do the job
triton
trend t11
any others?
tables is the triton any good as i need a table saw as well
wizer
3 Mar 2005
If your just starting out and want a flexible system then you can't go wrong with the Triton. Get the workstation, router table, saw and router and you'll be all set up.
Welcome to the forums.
les chicken
14 Feb 2005
south wales
I second WIZer on the triton router, if you buy one of these you do not need a riser as it is built into the router.
Les
paulm
IG paulm_outdoors
25 Sep 2005
North Hampshire
Go for the Trend T11 and build a half decent table for it. Works a treat and will save a packet compared to seperate raisers and commercial tables.
Waka
8 Mar 2004
Weymouth
Mukka
Welcome to the forum.
I don't have the triton in my tables, but previous threads give it a good write up, I'm even thinking of changing my T9 to a Triton. Whatever you do spend the time to make your own table, it will be a lot better than any shop produced one and a lot cheaper.
mukka
17 Nov 2005
cheers guys
so i should build my own table
but what about the battle between the triton and the trend t11, i know i can raise the router above the table with the trend can i do this with the triton or do i always have to reach under
are there any other manufacturers who include the raising function on there routers
ByronBlack
4 Sep 2005
Thurrock, Essex
From the reviews i've read, the Triton beats the T11 hands-down for use in a table as many of its features were specifically designed for table use.
However, on this forum there is also a good shout for the Freud unit (forget the model No.) so if money is a factor I would look into the Freud aswell.
ByronBlack
4 Sep 2005
Thurrock, Essex
I'm not sure, but there is a fairly detailed review/post of it somewhere here in the forum, you might be able to find it with the search, unless anyone has a direct link
A
Anonymous
Guest
I have the Jessem Mast-R-Lift with the Porter Cable 7518, and I cannot recommend it highly enough. Together with a Jointech fence on a home made cabinet, the accuracy and ease of use are a revelation. I previously had the Axminster table with cast iron fence, and there is no comparison. If you can stretch to the Mast-R-Lift, go for it, you won't regret it.
Max
baldylocks
19 Nov 2005
west yorkshire
I use a home made table with a 2050watt b&q router with springs removed, to raise / lower I use a straight lift scissor jack from an old car this lifts / lowers by around 1.5mm for half a turn....
I used this router due to its power and price it handles door components without a problem!
router, table and jack/raiser for under £110 what a deal :p
mukka
17 Nov 2005
like the sound of that but is it good solid and does it stay square,
how didi you mount the jack router and table together.
OPJ
31 Jul 2005
North Somerset
I'm after a router myself, but my budget (at this stage) isn't really big enough to allow me to go for a 1/2" model by Trend or someone similar.
There was a time when I was satisfied with changing over my Makita 3612CX - which happens to be my only router AND 110v - that idea soon went out the window!!
I'm after a decent 1/2" router (as close as possible to) 1850w (my table's maximum allowance) that won't break my 'student-size' bank account.
After flicking through the Axminster catalogue, I have noticed one of their models - on sale now for £89.99.
Anyone have any experience of this particular model?
Aside from that, what I've seen on eBay is either 1/4", too much or perhaps lacking with power - after that, you're looking at the £35 Erbauer <eurgh!> *shudders* from Screwfix.... :p
Any help at all and I'd appreciate it.
I'm also going for the WoodRat raiser bar option. It did get pretty decent reviews in Good Woodworking and I am on a budget here.
baldylocks
19 Nov 2005
west yorkshire
the jack is bolted to a 38mm fixed shelf (2x18mm mdf) by its own base, my jack base is square so setting that was a doddle, top of jack has a deep channel/mouth so I shaped a piece off oak to fit the top of the jack then slightly cupped the other side to fit the router but don't block cooling vents they do work :shock: as for any movement not noticed any! note of caution though KEEP threads on the jack free from saw dust :twisted: its areal pain in the :!: to clean i had to unbolt mine so be warned!!![/quote]
LyNx
27 Jul 2005
swindon
if your just starting out, i wouldn't spend too much money on items that you may not understand or get on with. Buy a cheaper model to get you going and once your skill develope then purchase the items to fit your means.
I want to spend £500+ on a good router but i can't see the point at the moment because i'm not making anything to warrant it. So i bought a cheap secondhand router from ebay (£10) and made the table and raiser to suit this. total cost was around £25.
I used this last night to rebate some glazing bars for my greenhouse and it worked great.
Andy
