Hey all. I'm after a little advice about routers if you would be so kind.
I've had a cheapo BandQ router for a couple of years that got used once for a specific purpose, which went badly mostly to my lack of knowledge on their use.
Now I'm getting into woodwork a bit more, I decided to dig out out and learn a bit about using them. I've just bought a router table to use with it.
On most bits, I have to raise bit in the collet a fair bit to be able to get the cutting edge all the way past the base plate. I can't do what is suggested, which is drop the bit all the way in and then raise something like 16th inch and tighten the bolt. If I do that, the cutting edge just about protrudes past the base plate at full plunge.
As the router table effectively has an extra layer of depth, using it is impossible (with that router anyway)
If I pull the bit out to almost at the end of the shank, I can just get the entire bit through the hole on the table, but surely this is not safe.
Am I missing something, or do I just need a better router that would provide more depth adjustment? I thought mine would do it as there is a fair bit of plunge depth, but like I said, it's no use if I insert the bit in the recommended way.
H
Sent from my GT-I9300
H
