Grahamshed
I have never used one of these before but it seems I need to get an 8mm collet for my desalt 625 so I can use an 8mm uncut spiral ( doesn't seem to be available in 1/2 inch shank ) do these cause any problems ?
marcros":i6ypfz7j said:do you mean an 8mm collet, which replaces the 1/2" collet in your router, or an 8mm collet reducer (collet reducing sleeve), which slots inside the 1/2" collet and allows you to use the 8mm cutters?
I dont see an issue with the former, but have not used one. I have used the latter with no problems. The latter will be cheaper, but shop around- the trend ones are very expensive compared to others available.
