Moreorlessright
This is only for the electrically savvy! If there is someone with an old (mine is 1979, its serial number is 100078) HC 260 that they could quickly peer inside the switch box of they'd be my friend for life.
My capacitor went, and when the replacement had a different type of connector (wire rather than spade terminal) I had to open up the switch box. I gave the capacitor wires an injudicious yank, one of them came away in my hand (honest!) and I can't see what it used to be attached to.
Looking more closely, the other lead from the capacitor is joined straight to a green wire that comes out of the motor body itself - presumably the starting winding. The other one is now connected to a short, dangling, piece of brown wire - the cap has clearly been replaced before, not particularly well. I THINK it should be connected to one of the terminals on the relay, in parallel with what seems to be one of the running windings. If the photo has uploaded properly you can see which one, terminal 34/32 on the relay, just next to the spring.
If I don't hear from anyone I'll give it a go - it can only blow a fuse, can't it? - but it would be wonderful if someone could have a look. Or maybe you know where there is a wiring diagram?
