Record 9 1/2 plane mouth lever
fenhayman
13 Apr 2019
Ely
I am renovating a Record 9 1/2 plane for my grandson to use on a woodworking course.
It's in good order but is missing the pin or stud to which the mouth lever is attached. The brass knob and slotted fitting are present.
Can someone tell me if the hole is threaded or was the pin a press fit.
Dimensions would be very helpful.
Thanks in advance
Bob
Ttrees
Iroko loco!
18 Nov 2012
In me workshop
On the Record/Irwin 60 1/2, the slotted brass thing with the pin will fall out, if you unscrew the threaded brass thumbscrew, and turn it upside down.
Tom
toolsntat
Yep, I collect tools and tat
8 Dec 2007
Leicestershire England
Some were a spiral push fit.
I've had one with a cut down plaster board clout in it for years though.
Cheers Andy
