Yetty
Hello,
Between coats of hardwax oil, I like to use 400grit wet & dry with White Spirit.
However, the grit has a tendency to part from the backing. This leaves black specs on the work that I then have to remove.
Any recommendations welcomed for wet & dry brand/types that might avoid this happening?
Many thanks
(So far I've only been using the cheap wet & dry from Screwfix, Toolstation. I've also tried nylon type pads but these don't seem to do such a good job)
Many thanks
