Re-fillable Caulk/sealant gun
Joe Shmoe
8 Mar 2008
I need a sealant gun that I can dip the end into a large bucket of thin Glue, suck it all up into the gun, and then dispense it out.
Just like they do in this video ...... But the offical one is £100.
https://youtu.be/-f4Y3tVOYKI
https://www.affixit.co.uk/Green-Glue/Gr ... enser.Html
I see loads of similar guns by Sika /silverline/ et Al, and significantly cheaper.
They look identical on the outside, but I'm wondering if they are perhaps missing a suitable seal on the inside to allow the 'sucking up' to occur.
Does anyone have one of these guns or any experience?
I clean out silicone tubes and re-use them for glues etc. Also good if you break a tube of glue or sealant, you can decant into one of the clean tubes. Very handy to keep a few on hand.
Great idea. Assume easy enough to push the base out from the top?
Yep. Push it out using a bit of rod, ideally before everything has set in the tube.
Then put the rod, tube, and plunger aside on a piece of greaseproof paper or cling film and leave it for a week or so. Don't attempt to wipe or clean anything.
After a week it will have all cured and will peel away cleanly leaving you with a perfect empty tube and plunger.
I use the same method with nozzles. After I finish with then I leave them out to fully cure. I then put the tip against my compressor blow gun and give it a blast at 100psi. The plug will come flying out and you will have a perfect clean nozzle to add to the spares collection.
Lidl sell a refillable silicon gun for around the £4 mark. Might be worth having a look
I clean out and refill the tubes from solvent free gripfill - they're easy to flush out with water, and the hole is big enough to use a bit of 15mm copper pipe to push back the plunger.
Very handy for getting plasterboard jointing compound into gaps and corners without dropping it everywhere.
Screwfix have just launched a range of sausage products with there own gun. I may switch to this in the future as I use a fair amount of tube based products and the waste adds up.
Adidat
Thanks.
Yeah, always cleaning out the nozzles, either with a long screw driven in when all is set or as you mention, a blast of air.
