production line reindeer and angels
mac1012
28 Oct 2011
chesterfield
here are some pics of what I have been up too production line of angels and reindeer a genuine santas workshop !!
due to other commitments I have decided to do just wholesale this year although I may do one craft fair near Christmas
I got wholesale order worth 300 pound so its quite nice cutting out stuff knowing I going to get paid for it :lol:
Also I just sell blank so no decorating or boxing.
putting some of money towards some hand tools for Christmas
The pile actually got bigger than this after photo , customer is picking first part of order up today.
The reindeer is now made from 12mm birch ply.
another bit of news is my electrician friend is putting power and lighting to work shop consisting of 6 double sockets and a light and he only charging me for materials that comes to 220 pounds so I really looking forward to that.
    205.2 KB
    175.9 KB
    177.9 KB
    166.1 KB
looks great mark, i also cut wholesale for a guy that has a laser cutter and a cnc machine (go figure) but i cut out thicker stuff for him. Do you know what thickness's the birch ply comes in as i may try and persuade him to go that route, at the moment i am using 20mm pine and the quality can be hit and miss..
hi steve I think the thickest you can get is 18mm which is not far of 20 mm I guess :shock: I think you can get it in 3,6,9,12 and I think even thinner at 1.5mm hope you are well and making plenty of sawdust :D
mark
Hi
Is the direction of the grain important on the angels? I ask because you could increase the number produced per length of stock by about 30% if you interleaved them head to head.
Regards Mick
thanks for your comments guys boysie hope you are keeping well , the mdf was only a try out last year , for about 6 angels only time I used the stuff and wont be again anytime soon !
Spindle I think I know what you mean but I buy the stock which is just over the width of one angel at its widest point so there isn't enough room to interlock I have found it the best way I just buy it in meter lengths or just over so I can fit 8 or 9 on without any waste length ways , due to the shape inevitably there is waste , but the lengths are relatively cheap , I keep saying every year I gonna buy a chimnea for the patio so after cutting in the workshop I can light a fire on a cool spring/summer/autum evening , maybe next year ......
mark
Hi Mark
As soon as I hit send I knew I'd not explained well enough (homer)
I'll try again:
If you place two angels head to head on the stock and then twist them in opposite directions until the heads meet the edges of the stock you will then be able to slide them together so as the heads move past each other. This placement should save you about 30% in materials.
Regards Mick
have a look on lathams website, up to 30mm available
Thank you, i have just looked at them and i need to buy at least £230 worth or they may put a surcharge on, i dont mind that but i dont have room to stack it all, oh well i will keep searching for the illusive 25mm pine..
Stevebuk, there is a place in Ilkeston that sells birch plywood.
It's good quality, good price and they cut to size and sell in 1/2 sheets too if it's of any help.
It's called... Ilkeston Ply.
Only problem is that its a small company and only delver very locally.
I got some 18mm and 6mm last time and although it had a few butterflies? In it, there were zero voids even after cutting into small pieces.
Last time I was there, these were the prices.
6mm birch £27.50
9mm birch £33.50
15mm birch £45.00
18mm birch £49.50
I don't know where abouts you live in Nottinghamshire though so may be too far.
Hope this helps.
6mm birch £27.50
9mm birch £33.50
15mm birch £45.00
18mm birch £49.50
Hope this helps.
thank you very much for that, i will contact them although i need to go thicker if possible...
Mark.
You have been busy, I think you may be on Santa’s pay roll. :wink:
Steve.
You have probably thought of this, but sticking/bonding ply boards together you can almost make up any size/thickness you want, I have done this using Tight Bond III, after cutting, looking at the cut edge you cannot see that it is bonded.
Take care both.
Chris R.
Mark.
ChrisR":1dw7gcyx said:
Mark.
Steve.
Take care both.
Chris R.
Mark.
thanks chris, need to see if the client wants ply, mdf or pine for the cutouts, managed to get 25mm pine last year but the guy has retired and the new owners cant get it..
These are the start of it..
    22.6 KB
look nice steve I use pine a lot I love the grain patterns although can be a bit resinous at times the one I use at allan and ore is 21.5mm thick
spindle I see what you mean now next time I cut some I will have a look , it will make the grain come across diagonally so not sure if it will look ok.
power tools its a steve good pattern he does a family but I just do the male
cant find the link but if you type in reindeer on his page or type steve good reindeer in google it should come up
mark
mark
Thanks for that I have found the pattern and will make one to go under the tree.
