Hi guys. Most of you will have seen me asking lots of questions on shop wiring. Here's what may be a useful snippet of information for anybody needing to buy a workshop consumer unit.
I spent quite a bit of time figuring out the parts needed, and how to wire one, and was set to order the parts when our local ABB operation told me (when I called to clarify a point about isolator types that the local wholesaler couldn't) that they could supply one pre-wired - and probably at a saving over my buying the parts separately.
It turned out to be a dead convenient and totally painless undertaking - and apart from the saving in my own labour and dandruff (from head scratching) I saved around €20 on a €140 unit. The CU by the way is a 24way split 100A unit with a 63A isolator, an RCD and includes all the MCBs and wiring.
I have an inverter driving my dust system fan and this with the rotary converter for the bandsaw seemed likely to cause nusiance trips in any usefully sized RCD. Everything else - the 4x16A machine sockets, 1x10A supply and 3x13A socket ring mains - is RCD protected. All of the MCBs are C types.
It's very straightforward to install from there forward - just hook up a supply, and the relevant circuit to each MCB.
I'm in ireland, but chances are there's similar services available in the UK...
