Colarris
Some of my dovetails butt out too far and I need to shorten them. Whats the best way to do it? I know if I try and plane them it will probably split the wood.
Flush cut saws are a pointless PITA and dead slow in my experience (limited!).LuptonM":2sde0ydo said:Flush cut saw then plane?
That sounds a little odd to me :-k It could be that the blade is skewed in the frog or that it's actually cambered. In my LN block the blade has been honed dead square with just the sharp corners knocked off so that it'll cut at whatever part of the blade I choose. I'd sight the blade along the sole to check that there's an even projection and adjust accordingly - RobColarris":2yroqaod said:Ended up with the joint made and just hacked at it with a block plane. Done the job but reminded me how 'random' planes seem to behave! I've found, with my brief experience of them, that there is only ever one part of the blade that actually makes contact with the wood. With the dovetails I had the move the plane in all manner of positions to find a section of blade that started to cut.
It can only nick the high points until you've brought them down to a levelColarris":p3akjl53 said:....that there is only ever one part of the blade that actually makes contact with the wood.
That's OK. With a cambered blade (or just tilted) one bit will cut better than another, so you move it about, or change the tilt.With the dovetails I had the move the plane in all manner of positions to find a section of blade that started to cut.
Colarris":17lpxtwh said:Ended up with the joint made and just hacked at it with a block plane. Done the job but reminded me how 'random' planes seem to behave! I've found, with my brief experience of them, that there is only ever one part of the blade that actually makes contact with the wood. With the dovetails I had the move the plane in all manner of positions to find a section of blade that started to cut.
