Hi all,
I've been trying to flatten some boards today on my planer/thicknesser (a Record PT260X) and have been having some troubles. I'm finding that the boards are forming quite a severe wedge shape. The leading edge seems to be being planed at a bit of an angle, so when I put pressure on it on the outfeed table, it's lifting the back of the board up. I've tried feeding the wood in both ways round and trying both faces but, even if I don't start off with this angled reference at the leading edge, it seems to form after a few passes. Obviously if I keep going I'll end up with a flat board but with no where near enough thickness left at the leading edge, as the flat face will be at such a different angle to how it started.
I think the problem is down to my technique, but I'm not quite sure what it could be. My general process is the following:
- Set the in-feed table to a fairly shallow cut (usually 1mm or less)
- Set the guard to cover the entire cutter block, with the height set a couple of mm higher than the stock that I'm using
- Place the stock face down on the in-feed table and, applying light pressure start to feed this towards the cutter block
- Once an inch or so of stock is showing on the outfeed table, apply moderate pressure to this and pull the wood through
This has worked well for me for the most part, but usually I've been using significantly narrower boards. The one I'm currently trying to flatten is about 250mm wide, whereas others have been less than or equal to 150mm or so.
In terms of machine set up, I haven't given it a thorough checkover yet, but have checked the height of the blades and they seem to be correct and consistent across the width of the cutter block. Everything else I can think of with the set-up was set at the factory and has been fine for all the other boards I've used it on. I want to make sure there's nothing obviously wrong with my technique before starting to blame the tools!
Any guidance would be appreciated, I've had a search through the forums here, and on google, but can't really find anything that explains a solution to the issue I've got beyond setting blade height which I'm fairly confident is correct.
