Picador Sander Bearing Replacement ?
Des333
27 Jun 2016
Newcastle upon tyne
Does anyone on the forum have any information on changing the bearing on the rollers?
Now that I have it up and running there is a slight wobble on one roller. Any information on the size of the bearing would also be a help. Thanks.
I can't help with how to dismantle a machine I don't know but bearings are standard parts and readily available in metric and imperial sizes quite cheaply via ebay/mail order. Measure what you have got, decide if it is metric or imperial. For dusty applications bearing with suffix 2R or RR which means it has 2 rubber seals, will be the best to use and only a few % extra.
hth
