Turbo
After converting my workshop over to use only one type of air fittings I have my unused fittings for sale.
All the fittings are PCL type 19/rectus 19/series 19 fittings, probably the most commonly used in the uk. All the fittings have been used and show some wear & tarnishing but they all operate perfectly & do not leak, I tested them all!
BEFORE REPLYING TO THE AD PLEASE READ THE TERMS & CONDITIONS AT THE BOTTOM!
1A - Male type 19 connector x 9.4mm hose barb, 4 available - £1 each
1B - Male type 19 connector x 7.95mm hose barb, 2 available - £1 each
1C- Male type 19 connector x 7.4mm hose barb, 1 available - £1
5A - Female type 19 connector x ¼” BSP female, Legris Series 19 branded, 3 available - £3 each
5B - Female type 19 connector x ¼” BSP female, PCL Vertex branded, 1 available - £3
6A - Female type 19 connector x ¼” BSP male, Legris Series 19 branded, 2 available - £3 each
6B - Female type 19 connector x ¼” BSP male, PCL Vertex branded, 1 available - £3
7 - Female type 19 connector x 3/8” BSP female, Legris Series 19 branded, 1 available - £3
8 - Female type 19 connector x ½” BSP male, PCL branded, 2 available - £3 each
9 - Female type 19 connector x ½” BSP male, PCL Vertex branded, 15 available - £3 each
These fittings came on some pipework manifolds I bought that came out of a factory. They are a bit stiff from lack of use but they work ok with no air leaks. They could do with a spray of silicone oil to help things but I didn’t want to do that in case they are used for a paint spray gun.
They have quite a lot of meat at the inlet side so you could easily tap them ¼” bsp and use them for hoses.
10 – Compair bayonet fitting x 3/8” BSP male, 5 available
Compair bayonet fitting x 3/8” BSP female, 1 available
I have no way of testing these but the valve is free in all of them - £5 for all
Now the terms & conditions.
Reply on here or via PM.
Easiest way is copy & paste the item you want or tell me the item number & quantity.
Postage will be extra at cost price by either Royal Mail or Hermes, your choice. I will package your goods, weigh them, let you know the prices & go from there.
All payments will be by Paypal, either as a friends & family’ gift’ or normal if you pay the fees.
If you are buying multiple items I will offer good discount, just ask!
Finally, thanks for your interest! 8)
