Parkinsons Perfect Vice Advice
cjp
16 Jul 2010
Chagford, Devon
Hi all. Life kept me away from woodwork for a while - but I'm now back, and in good timing have been lucky enough to be given this "Parkinsons Perfect Vice 15" which come more clement weather will become part of a "proper" bench (lack of space means I'll be building that outside).
Seems in very good knick for it's age, works smoothly and the quick release is a charm. I think others here had one and the thought was it dates from 30-60's at the most recent? I'd imagine the red paint is original as I can't see anything else underneath and it's in every hidden spot too.
After cleaning out some sawdust, I can't see it needs any real work - the rust is superficial really. Any advice on if/how/where I should oil/grease it? Does anyone bother re-painting their old vices?
Thanks all.
    124.6 KB
    67.1 KB
    110.7 KB
Good solid vice, should last several lifetimes. Painting would spoil it in my opinion.
I'd just wipe over with an oily rag or if you want something prettier wipe a mix of boiled linseed oil and turps/white spirit and wipe off the excess. That will leave it looking old but stable.
For the moving parts just 3 in 1 or similar. Or if you want something slippery but dry (so as not to gum up with sawdust) a bicycle dry chain lube such as Finish Line Dry.
An afterthought on the use of boiled linseed oil over old painted metal. A while back, I bought a lovely old treadle powered lathe, where some of the bigger bits of cast iron had less than perfect paintwork and I used it successfully on that.
From this
to this
with a little light wire brushing in between.
Plenty more pictures in this post and in the rest of the thread: https://www.ukworkshop.co.uk/forums/post791779.html#p791779
