OSB 3
No skills
6 Feb 2011
Hanging by my fingertips
Hello folks.
I have a t&g oak floor to lay but need to put a subfloor down on top of the joists first, is osb 3 suitable or should I use an exterior plywood instead?
I'll prolly be using tounge-Tite (sp?) for the fixing of the oak to the subfloor.
Regards.
Why not use 18mm chipboard flooring?
This means you will have joints between the boards rather than a butt edge
EDIT
Now I have read up on OSB3 flooring I would go for that.
I would use wisa flooring ply but I do not have to quote other people prices they might not like (for this sort of thing).
Ive used osb3 as a sub floor for oak flooring, although that was a flloating engineered floor not solid oak
I dont think osb would hold tongue tite screws sufficiently well so maybe ply would have better screw holding.
This is good advice =D>
There's a lot of power in that oak and I agree with Robin, the screws could pull out.
I once saw a solid oak floating floor by Junckers that had crushed 15mm copper pipe feeding radiators.
