I fitted my Elektra Beckum 315 bandsaw with the Bedford Saw guide conversion. Simple enough if you have an air hacksaw handy. I also changed the tensioner to a 10mm rod with a thrust bearing (thanks for the idea, Woodpig) to make it easier to tension.
All fine and dandy, good tension, no blade flutter.
Then the lower tyre decided to come off, just a bit, enough to vibrate like mad.
Before I could hit the stop button, plenty of sparks as the new Tuffsaw blade took a gouge out of the bottom door catch. Scrap!
I also recently bought some walnut, 6" wide, 30mm thick, 8 feet long (nice mix of units!). This was earmarked for a longcase clock case. I had the supplier re-saw it in half (about 14mm thick).
I can now make bananas with it. Bent both along its length and across its width.
Expensive firewood? Or can it be rescued? Or did I choose the wrong wood for such a project? So far I've been re-sawing it to remove the warp and using short lengths as contrast in bandsaw boxes.
I should stick with metal.....
Peter
Peter
