Nicknoxx
I need to make some architrave to match existing ,so I've bought a Dakota Router table from Rutlands.
The surface of the table has a few chips in the surface, some of which have been 'covered up' with a tippex type material. Is this acceptable?
The insert isn't flat. On it's own there's a dip of about 1mm in the middle but with a heavy router hanging off it this increases to about 2mm. Is this normal or acceptable?
The mdf fence cheeks (for want of a better description) are not perfectly aligned and a small shim would improve the situation. Where can I find such a thing?
Finally, which direction should I feed material in?
Thanks all
Thanks all
