Some daftie questions here folks. I've built a bit of stuff before, but this is a more substantial project for me and will be using a fair bit of wood, so I don't want to waste £££s and get it horribly wrong.
I want to build my son a "convertible" bunk bed, I have plans in mind, but it's to fit a specific space in his room, will have a single (70x200) bunk up top with usual fixed ladder, rails etc. as well as a 30cm shelf running down the wall side (why do no "bought" bunk beds allow anywhere for them to keep books etc. next to them?) - so 100x200 roughly.
Underneath, there will be a fold-away second bunk, which when folded away will allow me to put a desk & chair and bookcase (all on castors) under the main bunk. The foldaway bunk will push to the wall and be secured by a lock & hasp (kids, eh!) - another reason for the shelf on the main bunk is I'll need c. 30cm to play with to get the mattress folded away on top of that bunk. Cunning! It's intended to look a bit like this (linky here), but with the staircase going down to the floor and the bottom bunk being fold-away-able. And an shelf making the whole thing wider. As for slats, I'm afraid it's hard to look past IKEA's £12 slatted base - for that price I can't make it cheaper & better.
Anyways, the design isn't really what I'm asking about (although comments very welcome)... it's more about construction materials.
I will be varnishing (eventually) and although it doesn't need to look ultraslick - it's a kid's room after all - I don't really want it to look obviously homemade and "cheap". Which has dispensed with my original idea to use CLS as the building material. Radiused corners and edges would look dreadful.
However, I'm still swayed by the cracking value of CLS - under a quid a metre!
What is the downside to taking a 38x63 length of CLS and cutting off 5mm of either "long" side, giving me what would effectively be 38x53 PAR with better, square corners and edges?
The CLS I've been using has been surprisingly straight (and that's just from B&Q) and it's actually made reasonable rails/aprons for my workbench, which was 180cm long so a comparable run of timber. I don't have too many quarms about the bed being not totally 100% accurate to the thou.
I'll be using my table saw etc. to cut, so I'm more relaxed about it being a touch more difficult to work with.
I can see some 44x44 PSE redwood for about £2.70 a metre, which is a fair bit more but not outrageous. Obviously it will close to triple the cost of the build, but if that's what I have to do, that's what I have to do...
Thoughts?
Thoughts?
