"New" Saw
Harbo
In Memorium
13 Nov 2006
Hampshire
I bought a Crown saw having read that it was FWW's "Best Buy" but was not very happy with it?
Following David C's advice I filed down the kerf but still not OK, especially having handled Rob's (Woodbloke) LN saws - the Crown saw felt really clunky!
So after a few hours work with bandsaw and rasps on an off-cut of spalted beech:
Still not a LN, but a much better feel to it (I copied the shape from an old saw of mine).
I used my collection of cheapo Workshopheaven, Dick's & my 1 Auriou.
You certainly get what you pay for - the Auriou which is a grain 13 (fine) removed wood faster and finer than the coarser cheaper ones and was the one I kept going back to.
Rod
Rod,
I do like that. :D
I have a few old saws I bought to practise sharpening on, before I need to sharpen the nice Alf supplied ones. I might just try making a handle as well. :roll:
Dave - the hardest part I found was cutting out the slot for the brass back - perhaps some of our saw experts can give some advice?
I carefully mortised it out after I cut the blade slot - with hindsight perhaps should have cut the slot last?
Rod
Harbo
Nice handle!
When I rehandled my old tenon saw, I took Alf's advice and cut the slot for the saw blade first i.e. before I did any shaping at all. That way, if it all goes horribly wrong, you haven't wasted any time in shaping a piece of wood that ends up in your "odds and ends" bin!
Mike Wenzloff's websight has a lot of useful information on how to cut the mortise and general shaping of the handle.
Regards.
JesseM - Spalted beech is discolouration caused by fungal attack - found on other timbers too. Here's a vase I made a while ago even more figured:-
I think the saw Alf made did not have a back? The trouble with cutting the slot first is that you have to clamp it to prevent the slot opening when you cut out for the back. Also I had to cut quite deep to accommodate the blade profile - more than I wanted as I would have liked to reduce the amount of rear end overhang?
I could not find MikeW's website only his Trade one - no instructions on that?
Rod
