Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
I'm really frustrated.
I was trying to use a very short length of T-track, 3/4" size, to fix an issue with my bandsaw table. It's going to be surface-mounted on one edge of the table.
So I drilled a mounting hole and carefully tapped it to M4, and put a countersunk machine screw in to hold the T-track temporarily in position. The second hole was done by drilling through both the T-track and the cast iron together, so that the T-track stayed aligned correctly (even if the location of the hole wasn't spot on). This also worked a treat.
I was reaching for the M4 tap again when I realised what a twit I've just been: the first hole I used was a pre-drilled and countersunk hole in the T-track. It came with them already drilled at regular intervals.
The second hole, on the other hand, has no countersink, and it seems I can't make one as I don't have a countersink that is narrow enough to reach down through the open slot in the T-track (about 8.2mm across) to make it!
Any machine screw not countersunk properly will get in the way of the square nut that needs to slide in it. So no countersink on the hole = can't fit the T-track to the saw :-(
So I rummaged around and found my smallest snail-shell. That will just about slide along the track and I can get the point into the drilled hole, but I can't rotate it! I even wondered about reducing its diameter, but I think it would end up in two pieces. That idea isn't going to fly.
D'oh, as Homer would say. ](*,)
Can someone please point me at a source of supply for small (i.e. narrow) countersinks?
Failing that I can always freehand grind the point of a twist drill, but the result probably won't be pretty, and it's a lot less controllable too. Actually I can use the depth stop on the drill press for that bit, so it may be possible...
TIA
E. (feeling idiotic).
TIA
