Had some time on my hands ( at last )
so turned this :-
sorry about the brick !!
and the under side
so turned this :-
and the under side
Blister":3rxr0nlg said:...I came across a big soft knot that looks like it will fall out when i turn the inside
CHJ":23coytax said:Blister":23coytax said:...I came across a big soft knot that looks like it will fall out when i turn the inside
Then soak it in thin CA glue before you proceed, if no CA to hand then force as much PVA glue as you can into the cracks and voids to see if you can retain it.
