JohnMessUK
Hi All,
I have been interested in buying a lathe for a long time but was never sure if I would enjoy it or not so I bought a Clarke cwl1000 lathe and love turning.
Now its not the best lathe in the world but it fitted my budget and the thinking that if I could not enjoy it I could sell it on or take a hit on it.
I have a few things I could do with a bit of advice on.
1. When ever I sand even through the grits I am having trouble with sanding lines. They could be tool marks but I start seeing them when sanding. I start with 80grit then move up I keep seeing lines in the piece.
2. Hollowing out, I am having trouble with picking the correct chisel to use for hollowing out not bowls but more confined spaces. What is the best chisel to use for hollowing out.
3. Lathe speed. I have tended to keep my lathe at 1750rpm but it will go higher and lower can anyone suggest when it would be better to use a higher or lower speed?
I have attached a few pictures if you don't mind looking them over and giving any advice that would be great.
