Hi
I have an older motor which I am trying to re connect to the mains electricity.
The motor is a Crompton Parkinson
0.5HP
3.8A
Single Phase
220/240 Volt
50Hz
1425 RPM
and its rating is continuous.
-I'm pretty sure that is all that was on the motor plate
(Some of this information will, I'm sure not be necessarily relevant as being I gave the current and also the voltage, the power can be calculated)
From what I can remember and see from the image I took, the red and black wires go back behind the brown mounting plate.
The labelling on the brown plate, which I do not understand, is as follows; (working down) K,Z,AZ,A,T (there is also a S hidden behind the earth wire but as far as I can see, it doesn't do anything -in a similar sort of way as the K at the top doesn't seem to do anything either)
[for reassurance of my descriptive skills, the Z is at the top and has a yellow connection wire, the AZ has the blue and red wires, A has the Black and Brown wires, and T has the blue wire at the bottom of the image]
-->Just realised the image is orientated landscape which means the left is supposed to be the top
When I plugged the motor in like this (just a plug on the end of the cable as I was only testing the motor for now), the motor buzzed for a few seconds like a motor does when it can't turn and then the fuse blew. All rotating parts connected to the motor are free running and can be turned by hand (am I possibly connected to the run windings only or something?)
How do I correct this problem?
How would I connect the wiring so that the a reversing switch can be used also, or is that a separate affair all together and doesn't rely on the initial motor set up.
Hope this is all that is required for this problem as I have included everything I can think to.
Any help would be much appreciated
Thanks,
Harry.
0.5HP
3.8A
Single Phase
220/240 Volt
50Hz
1425 RPM
Thanks,
Harry.
