More a shop made machine
Thingybob
If it aint broke dont fix it
9 Mar 2021
Teignmouth Devon
Heres a machine i made a few years back when I found myself with a need for micro thin wood
20210324_162811.jpg20210324_162847.jpg20210324_162925.jpg20210324_163810.jpg20210324_163819.jpg20210324_163844.jpg20210324_185831.jpg20210324_163938.jpg20210324_163921.jpgIts a sander thicknesser using an old tumble dryer motor turning a n 80 mm roller wraped in 80 grit emery cloth it revolves at 1900 rpm and is adjusted by a pair of opposed wedges the bottom one conected to the screwed rod and wnen its screwed in it rases the bed up towards the roller controling the thickness. More in the next post
The machine is fully guarded and incorporates dust extraction 20210324_164020.jpg20210324_164030.jpg20210324_164803.jpg20210324_164103.jpg20210324_173023.jpg20210324_173116.jpgThis machine cost me nothing to make everything is reclaimed some scraps of hard wood,old ply,piece of guttering ,2old plummer block bearings ,piece of tubing ,old motor and pullys,v belt . Bits of perspex, old trolly from my wife ,oak cut out from a worksurface .The brown board with groves in (piece of laminate flooring ) replaces the green perspex when i need square or angular stock, The wood pics are of some stock i have machined the thin piece is 0.8 mm but i usualy only go as low as 1mm and up to 8mm perfectly safe if you dont try to over feed the roller small sandings you just have to pull the stock out from the other side at the end of each pass but it is fully guarded so your fingers are safe and no dust
    89 KB
Thats about the best home made sanding machine I have seen. I like the table arrangement and the guard and suction port. Well thought out.
Regards
Great job (y)I like the fact you used just bits n bobs you had lying around that have now been given a second life :)
Its a crying shame when i see firms throwing out good material and old machines i get tons of perspex from my son who works at a retail mall from old displays that have had their day well maybe a week its brand new material to me
At first glance I thought I was looking at an old Flip Top bin and thinking that might help tidy up my scraps corner,,,quite a shock to read its an ice cream tub!,,but its got me thinking about Addis Bins now though,thanks.
Steve.
