RogerS
As part of the flat refurb I hid all the pipework behind MR MDF..mounted onto 3x2 inch battens fixed to the walls. I've now noticed that where the joins are, fine cracks keep appearing in the paintwork. Has to be minor movement although the flat is in a stable (?) old concrete building...so maybe minor changes in the battens, I guess. Can't be moisture as it's not been used in anger yet.
I used 18mm MR MDF but wondered whether 12mm MR MDF might be better crackwise, as I have another identical flat to do? Certainly lighter 8)
